removing just transmission
Drift Machine
Car: 1991 KA-T 240sx
Hey has anyone on here removed just the transmission. Cuase i'm trying to do that right now and i'm having some trouble reaching the 3 upper bolts that connect the transmission to the block. Anyone have any advice if they have ever done this?
C-Kwik
Just reach up there with a wrench. There is no easy way to get these, but it can be done. It is tedious and will need plenty of elbow grease to budge it loose. The upper bolts tend to be the hardest ones to get to.
Drift Machine
Yeah, i just got all of them undone except for the very top one. It's not being very friendly.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Best idea is to remove the transmission cross member and allow the rear of the transmission to rotate down. This should give a little better access to the top bolts.
Dattebayo
yeah that and we used a really long extension for the air wrench (almost 3') with a swivel tip. that really cut down the work for those top bolts.
Drift Machine
Just got the transmission out like 15 mins ago. Wow those top bolts suck. Yeah we dropped the transmission and we were able to reach them with a little bit more ease.
clearview
when i did my clutch in my s-14 i had to turn the transmission on its side.this gave more clearance. i needed this clearance on the install.i went up and in when the transmission was about an inch or so from the block i turned it back upright to slide it in that last inch
Thor
I had to loosen the engine mounts, then drop the rear of the transmission... If I remember correctly, I reached the top bolts through the top of the engine compartment.
wiwalsh
Car: school, and my 240!
Yep, I did the same thing, removed the rear transmission mount. Then reached in from the top of the engine. Its still a bitcL to get to......
