Removing intake sucks!!!
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
redhat-z
Holy crap, this spider intake is a pain in the &$$ to remove. I removed, unbolted, or cut everything holding it down and there is still something next to the EGR. It feels like a hard line from the plenum to a soft line. I just can't put my retinas in there to see it.
I started pulling spark plugs to do a CR test before I pull the motor for the swap. Oil and AntiFreeze!!!! This sucks. No point in doing the test now. Its time for head gaskets, rings, bearings, valve seals, gaskets, etc.....
Oh well, I'm just venting.
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Yeah I've been pissed off by the plenum before, it's a mission trying to pull it off due to the lines directly under it holding it down >_<
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Theres a bracket holding on some metal tubes right by the hose right behind the TB. Its hard to see. you just have to remove a 10mm bolt
redhat-z
I even thought about a sawz-all.... but it wouldn't fit.
redhat-z
I'm gonna come up with something else after the rebuild because I refuse to put that GOSH-DARN plenum back on and have it sticking out of the hood of my 240sx. That's too gettofabulous for me. Even though I live in Fairdale.
Ezekial
Car: 2001 Nissan 200SX S15
the only thing under my plenum is the anti lag ABV
aftermarket ecu FOR THE WIN!!!!
you can remove ALLLLLLLLL the CRAP!!!!!!!!!!!!!!!
Raxephon
Car: '04 RX8...for the moment...
redhat-z wrote:Holy crap, this spider intake is a pain in the &$$ to remove. I removed, unbolted, or cut everything holding it down and there is still something next to the EGR. It feels like a hard line from the plenum to a soft line.
Odds are its the AAC hardline, its always a pita...............if you still have one.
redhat-z
Appreciate the diagram. Thats helpful.
Return to “VH45DE / VK45DE / VK56DE Forum”
