Removing Intake Manifold
Morph
Car: 91 Sr Powered Coupe
As the title says im replacing my head gasket and im having a ***** of a time trying to get the upper part of the manifold off. I have removed the fuel rail and detached all of the components but the ****er is still on. the bottom slides up no problem buty the top right corner doesnt move much. I know its aluminum so a crowbar isn't going to cut it so any tips.
Please any quick response is greatly appreciated.
ILikeMy240sx
Car: SR Power
did you take off all the braces that supports the intake mani?
BTW, its much easier to just take off the entire manifold off instead of doing pieces at a time.
Morph
LEt me go check pretty sure i did.
ILikeMy240sx
Car: SR Power
yeah i dont remember how many but there is/are brace(s) supporting the manifold to the block. Its black.
Morph
Right now im just taking off the top and i dont see any supports attahced to it.
ILikeMy240sx
Car: SR Power
thats why its much easier if you just take the entire manifold off not just top.
If you try to take the top off the studs on the head will get in the way. If you take the whole thing off, you can move it away from the stud to pull the manifold off
Morph
ILikeMy240sx wrote:thats why its much easier if you just take the entire manifold off not just top.
well **** i think that you just ruined my day
ILikeMy240sx
Car: SR Power
download the S14 manual and go to Engine Mechanical and look at the intake side of the engine.. you can see all the braces supporting the mani.
http://www.silviansw.com/manuals.php
ILikeMy240sx
Car: SR Power
Its really not that hard... much easier to take off the whole thing in my opinion...
When I helped my friend do his intake mani on his S14 SR... I just took off the entire thing. There were lines here and there that I didnt disconnect but you find those things as you try to remove the mani. Also I left out few braces which I also found out when I tried to remove the mani.
ser2102
Car: 91 dead. 90 getting did
hes right. i thought i could just take the upper part off, but it wouldnt come off the studs. turned out to be an all day event for me, with a sore back haha.
Morph
ILikeMy240sx wrote:When I helped my friend do his intake mani on his S14 SR... I just took off the entire thing. There were lines here and there that I didnt disconnect but you find those things as you try to remove the mani. Also I left out few braces which I also found out when I tried to remove the mani.
Ya i found most of the lines and disconnected them but i got 1 left on the back hard as a ***** to get some needle nose plyers in there to get it off though.
I looked at the fsm the s14 has like 3 more mounts than the s13. All i had was 2 holding it on.
ILikeMy240sx
Car: SR Power
Cool,
glad to hear that you finally got that farker off.
VitaminT
Car: 93 240sx SE
Yeah I think on the s13 it is just the one big one and then a small one up by the timing tensioner. That iacv coolant line is a pain.
Morph
ILikeMy240sx wrote:Cool,
Dont have it off yet but i will today.
spider_slayer
Car: S14 240SX
S13 240SX
i jsut disconnected the top from the head and pulled it back a little. took the turbo and all off the other side. this gave me just enough room to pull the head off.
