Removing Injector Connector - '94 Q45a
Brad-Man
Car: '94 Q45a w/Texasoil Accumulators
Definitely not like my old Bosch connectors - simple wire removal and that's it.
I'm afraid I don't have quite the eyesight to determine if there are any levers/pressure points/tricks to removing the connector from the injector or if I just pull if off.
I have ohmed mine and have 2 completely dead and one around 50. I'm in Atlanta same as Dennis, so I suspect I'll be replacing injectors on my 85K Q and want to see if they are the old or new style, and want to test at the injector.
Thanks,
Brad
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you have the later style. on the connector there is a tab you press down. Its like a tiny version of the main injector harness that you took off to ohm the injectors.
Brad-Man
Actually, I had to lift two tabs (one on each side of the connector to be able to pull the connector out of the harness connector. I DO se that I have beige injector tops. This car was originally sold 10/93
I got it off - just gave the tab a bit more muscle and it "clicked" like it was stuck when it opened.
My injectors have a total of 4 locating ribs - one on each side and two on the bottom. I thought this was the old style injector - darn - now I have to try and find the post showing new vs old...should be a sticky at this point!
Modified by Brad-Man at 10:36 AM 7/24/2008
Q45tech
Just que up in the waiting line, everytime I go to T3 I see a new injector troubled Q
elwesso
2007 BMW M Coupe
the old style have the square connectors with the metal clip that holds the harness on. The new style have the roundish connectors that have a push tab to hold them on.
Brad-Man
Yeah - I never found the post that had old vs new, but I went to another site and found it. I DO have the new...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Yes you do since you have a 1994. Why not complete your profile so we know exactly which model you have and where your local driving environment is?
Do you know about http://www.q45asuspension.com ?
TexasOil's posts are invaluable reading for any active owner.
Then you have the resources of T-3 available!
