Removing INFINITI letters...
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
370Z/28
Car: 370Z & Z28 *SOLD*
'13 Lexus IS250C F-Sport
It seems like all of the really slick G's I see have the INFINITI letters removed from the tail. I have been toying with the idea doing that myself. I was just going to do it like I have always removed emblems, heat, WD40 and some dental floss. Just wanted to check and make sure that nobody has had any problems doing this.
Warped161
Car: 90 s13 the never ending project
i use goo gone instead of wd for debadging, works great.
370Z/28
Thanks...I'll do that. Smells better too.
370Z/28
While I'm on the subject...would you remove the G37 also?
morrison82
Car: 05 Infiniti G35
Glad you actually asked this question. I am wanting to remove the infiniti from the trunk too. I thought the emblems were riveted on or stuck through the metal not glued on. Am i wrong. If so I also would like to know the best way to get them off.
joe603
Car: 2014 Durango R/T
The best way is to use goo gone and fishing line. Let the goo gone soak on the letters for about 5 min, then take a fishing line and use it to cut the glue. Another method is to use a hairdryer to soften the glue...but you'll still need goo gone to remove the glue once the letters are off.
They are not rivited on.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I removed the G35 from my rear and will soon be removing the INFINITI.
I tried a few different things, but this is what worked best:
Get goo gone or some other CLEAR COAT SAFE adhesive remover and lightly soak the adhesive backing.
Use fishing line or no-shred dental floss to "cut" through the adhesive foam.
If you're lucky the adhesive remover will have left you with a nice clean finish ...Yeah right!
Use some more goo gone and work the adhesive away until all you see is the outlines.
Now for the fun part. Clean up the area with some soap and water and dry it. Bust out a micro fiber polishing cloth and some 3m fine cut scratch remover. Buff it out and it will look like it was never there!
Note: Be careful with heat as it MAY melt/bubble your paint, then you'll be buying a NICO sticker to patch up your booboo.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Using a hair dryer will be safe...don't use a heat gun on this
goo gone is good to remove the adhesive
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
don't be like me and use a 2400 degree blow torch and chainsaw. I still havent been able to get rid of those remains. I had no Idea bone was so durable. Anyway, the investigation was dropped because of a lack of evidence, so I'm off the hook. Whats with all the cars and things around here? Oh wait... this is a car forum? oopss...
I've been at work for 10 hours. bored? yes.
370Z/28
Return to “G35 and G37 Interior, Exterior and Audio”
