removing healdight and signals on a '97
khilgers
How do I take out the turn signals on a '97. I took out th top silver screw but they don't seem to come out. Also since I'm replacing the low beam bulbs I've heard it easier to just take out the entire headlight, but how. Thanks...
NISTECH
may be another screw back in side if you look in from the bottom corner of the head light. also they are snapped into a grommet at the rear near the fender..if your sure the screws are out it takes a bit of force to pop it out.
f8sjester
there's a prong on the corner lights that holds them in. . . basically, just unscrew the one screw on top and then pull the corner light forward (along the path of light from your headlights). . . it should pop out with a bit of force. . .
i just hope i didn't miss any screws there heheh
edit: yah. . .what nistech said *oops*
