Q45tech wrote:Never seen a Q with a bad head gasket that wasn't overheated and that means a lot more serious work than the 25 hours to replace the gasket. If you desire to meet OEM specs afterwards.
Just avoiding the personal back damage is reason enough to pull the engine.
I will second the BACK ache issue ! Every time I worked on the Q durring my head gasket project, I would come home and pass out after having 2-3 Heinekens. One nite I went out to a bar with some friends and passed out on a lounge chair right after getting out of work- working on my Q for 4 hours.
My head gaskets where not blown, it was the heads that warped from severe overheating. I blew a few thousand mile old radiator after I bought the car because of so much pressure being built up in the cooling system. My machine shop was able to bring the heads back to OEM specs for 500 dollars, and that included a valve job, new valve seals I provided them, checking for cracks, hot tanking the heads and throught cleaning- as you can see in the pics I posted in the threads. I had fun doing this.... but I won't ever do it again. Car runs like a champ and I am very happy with the overall outcome.
