Removing gauge cluster PLEASE HELp
90fastback
Hey guys I just did a DE swap and need to put a 91+ cluster ni there, i have one but i cant get the effing bezel around the cluster off.. how the hell do i get it around the ignition and stuff ? do i have to drop the whole column or what ? help me out ! i have it all loose and stuff im not that dumb just cant get it out dont wanna break it
Hijacker
Car: '92 240sx Convertible
'94 F-150
there are two bolts up behind the column that will lower it out of the way. you'll need to feel for them and use an extension to get to them. i think their 12 mm bolts.
240Kuminachu
There are 4 bolts, 2 up front and 2 in back arent there?
912.0turbo
No you can just take the front 2 off and it will come out.Just did mine like 3 weeks ago.
wangless
Car: '02 MBP WRX
didnt know you could just undo the front two as well. dont forget when you get to the hazards/cruise/defroster/headlight buttons that you unplug them, or at least one side so you can flip it over and reach the cluster
