dllkbales1 »
https://forums.nicoclub.com/dllkbales1-u137663.html
Sun Jul 05, 2009 11:58 am
The banging on the tank usually works best if you bank on it with a large heavy hammer while someone is cranking the engine. When you pull the tank, less fuel is less weight and easier to handle. You could always put a hose in and siphon some of it out. To pull the tank spray everything first with penitrating oil. bolts clamps everything.If this tank is next to the driveshaft you may want to remove it for more working room.Loosen clamps on the fill hose and the vent hose, (the smaller on next to the fill hose). Spray a little oil in next to the tubes and work these hoses loose with a small screwdriver. Disconnect any hoses you can see coming off the tank and your wiring harness. There may be one place to disconnect off to the side of the tank or 2-3 seperate oned on top. Alot of extra hands will now become usefull. Support the tank on a floorjack, back off the bolts or nuts on the tank straps and bends them gently out of your way while balancing the tanks. If it falls things will break. Lower the tank slowly looking all over the top, you need to get everything loose. There will be a fill hose, vent hose for filling, fuel supply and fuel return (may require special tool), one or more hoses for the evap vent system to store fumes and burn them later. If you break it you must fix it our the check engine lite will come on and you will have an evap code. If you buy a good pump you will get the entire module assembly. The lines will most likey require special removal tools to release off the fuel module at the tank. You would put the tool around the fitting,slide it into the line to release the internal clips, push the line and the tool towards each other then pull the line off. Cheaper pumps may have to be put on the fuel module and then put back in the tank. The module will be held in the tank by a large snap ring or a ring you need to rotate of with hammer and punch. Clean this type well, blow out the dust and dirt before attempting to rotate, spray with oil. NO SPARKS PLEASE. A little vasiline on the o-rings and seal, lines and fittings will help it go together easier without damage to any seals. Damage a seal and this will be practice for the next time. Cheap pumps at discount stores have always failed during the warranty time that our shop offers. Its you time and money, chose wisely. Best of luck, Dave
