Removing Front Seats
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
williamk10
Car: '07 Nissan Versa SL
So who has removed the front seats?
I see a harness underneath the driver seat. I assume it is the airbag and seatbelt sensor. Is it safe to unplug? I should clean up my amp install under the seat and the easiest way is to remove the seat.
morgan
Car: Versa
Yes, just disconnect your battery, wait about the time it would take you to go inside and wash your hands, then disconnect the wiring under your seat. you'll be fine and there will be no harm to anything, unless you break the connectors, but you won't, so no problem.
Return to “Versa Technical Discussions”
