Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sun Nov 26, 2006 5:58 am
you can leave the head on and do that gasket fine. If you have a 1/4" swivel socket, you can get to the bolt under the exhaust cam easily.
But I do recommend that if you pull the front cover, pull the upper oil pan as well. The reason is that when you pull the cover, you're breaking the seal on the oil pan. It will never reseal properly unless it's a continuous bead, so you may experience a leak from that area.
Also, when you get ready to put the front cover back on, pull the oil pump spacer that's on the nose of the crank. You can get a bit of extra clearance so you don't mess up the front of the head gasket. I tried to put mine back on with the spacer in place, and all I did was accordian the HG and made it very unhappy. Thankfully gasketmaker has help up on that spot
