R240NA »
https://forums.nicoclub.com/r240na-u1367.html
Wed Nov 27, 2002 8:49 am
For the AIV and EGR, Nissan sells a pipe plug that fits perfect, it's actually sold for the purpose of AIV-removal. Easier and cheaper is to take the manifold pipe and cut it about an inch from the nut, crimp it flat and then fold it over, crimping it again. Then use it as a plug. The EGR valve itself can be used as a template to make a cap, trim out some sheet or stock steel and bolt it down, a good helping of silicone will seal it up. The carbon cannister lines run underneath the TB, cap them off with vacuum caps or crimp and fold the outlets there too.
