removing emissions just have a few final Questions
iceslick86
Car: 1989 240sx coupe
well i have already searched and i've read other articles on Nico and other forums and got some great info but i got a few more questions.
i need to know if i need to weld this hole shut where the egr control valve was removed
neverlift
thank you so much for not asking HOW to remove the emissions.
you can make/buy a block off plate, then use some high temp rtv/or oem replacement gasket....
again thank you
gumby74
I had some 1/4" aluminum plate left over that I used to make a block off plate. Just use the gasket as a template.
DaydreamDrifter
Car: 90 240sx 00 Altima
the metal tube coming from the IACV nad that other sensor, where do I need to run a hose to from that pipe?
spindrift187
EGR blockoff
Butterfly blockoff
Ran the FPR to the only vaccuum port left on my intake mani
Everything else(besides the PCV valve) was blocked off. Still maintains a smooth idle like stock.
nka24racr
Car: 91 acura integra, but missing my chuki......
iceslick86 wrote:well i have already searched and i've read other articles on Nico and other forums and got some great info but i got a few more questions.
what are your emissions regulations out there?
rps-13
Car: 1993 ka24de 240SX fastback
you mean to tell that you have removed the butterflies in your sistem and blocked many more things and you car is working properly???
pflicht
Car: 1991 Nissan 240sx - SOLD
2000 Lincoln LS - DEAD
1997 Nissan Maxima - DD
1991 Nissan 240sx - Project
rps-13 wrote:you mean to tell that you have removed the butterflies in your sistem and blocked many more things and you car is working properly???
Thats what I did and my car worked fine!
spindrift187
car runs great, holds idle fine(little higher as its getting colder but nothing erratic), and has a very smooth powerband.
I dont know why people insist the car will run awful if you remove everything.
sleeepy240
Car: 90 240sx hatch w/twim cam ka
95 240sx
the 240 u took the emissions off was it ur daily driver. i got a 240 daily driver i was thinking bout taking the emissions off. so ur car is idaling nd running fine no problems. i noticed on the fourm u put it runs alil warmer now. do u ever drive i out of town or anything?
xyzalvarez
*BOOKED
mistaremy
Car: 1991 240 sx
I want
neverlift wrote:thank you so much for not asking HOW to remove the emissions.
again thank you
I to remove mine after the E-test just wondering how much HP I'll free up
91 240 DE LSD(CAD) HICAS
Oh in addition I was wondering If any one has converted to an electric fan( I want to run stock b4 I rebuld the bottom but still scare Honda boys runnin stock)
MoldyOldy240
Car: 1991 240sx 295K w/ original engine.
Go to the junk yard and grab a set of dual altima fans, cheapest way to do it.
In the write ups section there are a few ways to wirer the relay into your electrical.
deadSeri0us
Car: 1989 240SX
I did the bypass on emissions with a plate and everything said. my problem is where do i put the EGR ITC what ever thing that looks like a saucer? do i leave it out? where do the hoses from the pressure regulator go to then? someone explain the fuel line setup without emissions please
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
yahoo alabama!!! i dont even know what a emission test is!
