you can remove the aiv connection at the bottom of the mani. but its a *****! hehe. i ended up using a pipe wrench. then i removed the bolted part off of the pipe and used a nickle to fit into the hole of the mani, sealed it in with the bolt.
as for the egr, did you try to use a breaker bar yet? you could just stick a pipe over the wrench.
