Removing ECU
frapjap
'07 Subaru Legacy
I need to get my ECU out of my car to hook up my a/c wire to the harness...i should have known I wouldn't live in Fl long without a/c. Logic on removing it isn't prevailing, so any help would be appreciated.
corn322
Car: 1993 240sx
it's behind the kickpanel on the passenger side. take it out, it's only got like 2 screws holding it in. I think you have to take the door runner off to remove it.
anyway, then the ecu is held in with 2 bolts, one on top and one on bottom.
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
And don't forget: remove negative batt. cable before removal or install. I've taken it out without doing that and been fine, but better safe than sorry.
BadMojo
Car: 2007 Mazdaspeed 3
Crispy fried ECU would be bad...definitely remember to disconnect the negative battery cable.
