SpartanAir wrote:.....but before I attempt to remove them, is there a trick to removing them safely?....... I have a small crack in it and I don't want to break it further.
I've been removing the door panels in the 90Q a lot lately to get to the amps. There's a large plastic pawl right behind the window switch on each of the 4 doors that holds on pretty tight. I've been prying across the top with a screwdriver just enough (1/4") to get 8 fingertips behind it. From there pull evenly all across the top and it will pop loose. Three more metal clips hold it around the perimeter but you'll be able to pull it out easily once the top edge is free. There's a few more steps if you're wanting to unplug it (removing the door panel).
