Removing door panel from 02 QX4
albert3029
Car: Infiniti G35x 2004
Need help on removing door panel from 2002 QX4? Would hate to break the clips like I have on previous vehicles. Thx!.
WINNIPEGS_MOST_WANTED
Car: 2003 Nissan Pathfinder
I sent you an e-mail with the instructions and pics. Let me know if any of it is unclear.
[edit] Guess I should mention those instructions and pics were from my 03' Pathfinder. I don't think there will be a difference though. [/edit]
albert3029
Hey, thanks for the reply but I can't see any pics or instructions. Please send the link again.
I used the e-mail in your profile (@yahoo.com) The instructions were plain text and I zipped the images. If you want I can throw it on my site and post a link...
wasmeaz
Car: 2003 Pathfinder LE
Please post or forward a copy to me. Thanks
I've forwarded a copy. I'll throw it all in a .doc later and post a link.
tanhvan
Car: 1999 Nissan Pathfinder
Hi, can you send me the pictures too ? Thanks.
I have a 99 pathy and need to replace the left mirror. Tried to take off the door panel, got 4 screws out, but got stuck with the door latch handle, the one use to open door with. Somehow, this latch is attached to the door even after the screw is removed.
Thanks a bunch
[email protected]
http://home.cc.umanitoba.ca/~u...l.doc
~8 megs (contains pics). This might not be a permanenty home for it.
gwhunt23
Car: 99.5 QX4
WINNIPEGS_MOST_WANTED wrote:http://home.cc.umanitoba.ca/~u...l.doc
Good work! I've mirrored it on my server at http://www.gwcustom.com/mirror...l.pdf
Let me know if that's not okay and I'll be sure take it down!
It's fine with me!
exprice
Car: QX4
Help I'm stuck. I can't remove my door panel to replace my passenger side mirror. I removed 2 screws on the door panel.Do I need to remove the simulated wood panel? I couldn't open your link .
