Removing differential???
Mikey_ZX
Car: 91 Infiniti Q45 1st Gear Start
94 Nissan 300zx N/A
2008 Chevy Aveo 5
2013 Toyota Venza Limited AWD
Hello again,
I need to remove my differential from the rear axle because I have a stripped drain plug, needed to know if I need the back wheels suspended to do so, I have the car raised, but I do not have the rear axle suspended!!! I need to take the cover off of the differential and remove the drain plug some how! Anyone do this before, will the rear cave in if I don't have the rear wheels suspended? Is it easy to install once removed? Any suggestions???
