Off to the machine shop it goes... In the trunk of my 350.
Anyone else have issues with breaking the mani studs off in the head? Is this common for RB motors?
Thanks.
RustspecS13 wrote:Ive had lots of my nissan's break exhaust studs.
NO NEED FOR A MACHINE SHOP!! Just weld a new bolt onto the snapped stud, there couldn't possibly be a better or easier way. I just used my trusty little mig welder and tack welded a 12mm bolt to the stud and backed it off with a wrench.
Since the head is aluminum and the bolt is steel, the weld will only stick to the steel. And the heat of the welding will break loose any galvanic corrosion that's holding the steel stud into place. Best of all no drilling, re tapping, helicoils, etc etc.
~Alex
