DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Wed Oct 08, 2003 8:28 pm
Chain wrench is the best way to go, but there is a little trick I've used a few times that makes getting the bolt off very easy. Put the socket and a long breaker bar on the bolt, and rest the bar against a very sturdy part of the frame (DRIVER'S side, NOT pass side). Remove the injector fuse and then just pop the starter with the key. The crankshaft will turn but the bolt won't. Just pop it for an instant to break torque, then undo the bolt by hand.
*DISCLAIMER*: This is a risky method. If the socket were to pop off at the wrong time or break, it or the breaker bar could fly off and damage something or injure someone. Always use an impact socket for this one. It's crucial you know which way the crank is turning and which side to put the breaker bar on. I haven't had any problems with my starter motor, but I can't guarantee this method won't be detrimental to it. ***Finally, if you don't have a method of keeping the pulley still, you won't be able to torque the bolt on later when you're putting things back together, so you'll need a chain wrench anyway. Starter only turns one way unless you want to jury-rig it, but that's dangerous and you won't know how much torque you're putting into it.
