Removing Clutch Damper
Edub1
Car: 89 240sx KA-T
I came accross an article that suggested that this was a good thing to do. It claims decreased travel and a better feel.
Also, I wonder if this could be the source of 1st and sometimes 2nd grinding problems. I know that when I shift quickly from 1st to 2nd I get a grind as is the clutch isn't fully depressed. And of course we all know the roling 1st gear issue.
Any thoughts?
Florida240sx
Sounds like it. I had to pump my clutch.. Clutch in get out of gear,release all the way,clutch back in to go back in gear. Got 2 SS lines as backup's for freinds. splparts frsports is where I got my last 2.
Logan76
Car: Junk
I dont know if it will help with your gear grinding problems, it could be due to your transmission, but bypassing the dampener makes bleeding your clutch a 30 second job compared to 4 hours, and its very simple, just take a small pipe wrench (what I used) and bend the hardline then it just screws together, easy a cake. I didnt notice much of a difference in pedal feel, atleast not as much as your assuming you would feel.
lrb_2000
Car: '91 Nissan KA-T hatch
I just disconnected it, and bent it by hand real quick.. My petal is extremely hard.. ACT Xtreme pressure plate, ss line and no dampening.
nissanfanatic
Car: 1992 Nissan 240sx SE
Rolling first gear issue is normal. You aren't supposed to go into first gear rolling.. I do anyways though..
Just remove that gay loop..
Craving4Boost
Car: 91 240sx fastback
I have to go into a 1st gear roll with my friends civic....too damn slow!
C-Kwik
You'll likely feel no difference in how the clutch operates, but you may get a slight vibration in the clutch pedal when you depress it at higher RPM's.
s13rb25det
Car: 92 240sx w/rb25det
I removed mine and installed a AP hard clutch line. I like it a lot it feels smoother and when I need to bleed my slave cylinder it doesnt take forever
