removing cluster gauge
LoxMurda
Car: 93 Infiniti Q45 212k R.I.P.
94 Infiniti Q45 180k and climbing
Is there any way of removing the cluster gauge on a 93 q45 without removing the steering wheel and where is the parking brake wire
goody90q45
Car: 1992 Infiniti Q45 (sold)
No need to remove the steering wheel. Tilt the steering column all the way down and remove the 4 piece steering column shroud. Getting the instrument cluster out is easy. Getting the trim piece that surrounds it is a PITA. Just keep wiggling it outward and eventually it will rotate forward and come out. Have patience with it.
LoxMurda
good looking! I got it had to install some led's..looks gd up thanks...any idea how to get to the lights on the shifter?
Q451990
Too late for you but it may be useful if someone searches and finds this in the future. The cluster trim comes out more easily if you remove the bolts retaining the steering column to the chassis (sort of a u-bracket)
Heath
DrewQ45
Car: 1990 Infiniti Q45
LoxMurda wrote:good looking! I got it had to install some led's..looks gd up thanks...any idea how to get to the lights on the shifter?
You'll find your answer here....
zerothread?id=244016
LoxMurda
ONCE AGAIN ...YOU GUYS ARE ALWAYS ON THE BALL...I APPRIECIATE IT! ONE DAY WHEN I GROW UP, I WANNA BE JUST LIKE YOU GUYS.
Q45man1
Car: 2002 Q45, 1994 Q45
What you're talking about, you are already a grown man
