Removing center bushing and rack oil seal
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
The service manual says to insert a 29MM socket though the side closest to the pinion. Yet the 29MM socket will not fit through there because its too large!
So how does one remove the center bushing and rack oil seal?
Could one use a long flat head screw driver and just hammer on that screw driver to get the oil seal out? Thats what I did with the rack oil seal closest to the end cover.
Is Rack Doctor still on this forum?
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
maybe they meant 29mm outside diameter...
Infinitiguy19
Damn I hope not because I already wrapped my breaker bar and socket in electrical tape. :(
Screw it I will spray some PB blaster then try a smaller socket and hammer it out.
