r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Wed Apr 26, 2006 1:35 pm
youll have to remove the water pump pulley. there are the allen bolts (cant remember the size), 2 10mm bolts in the upper cover, and 2 8mm ones in the lower cover. to take the lower cover off you need to remove the crank pulley (its a 1 and 1/16 i think?) because the cover wont clear the water pump unless you pull it straight out (towards the front of the car).
hope that helps. im really not that nerdy CA wise, but i had to do this 3 times in the last 2 weeks.
- Tim
