Removing C pillar exterior trim from 2022 Rogue
Popular_Culture
Car: 2022 Nissan Rogue
Hey all,
I got a 2022 Rogue SV and got some sticky gunk on the C pillar plastic trim from some construction being done outside my work. Tried to clean it off but the texture of the plastic got removed in the process. I want to replace this and it looks like I can just pry it off but was wondering if there were any more steps involved with that? I tried to search for this but did not see anything so if there is already a thread I apologize.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's called a Door Sash Cover Rear, and from what I can see it's just a few clips and double-stick tape (7 and 8). The tape and clips should come already attached to the new piece, but be prepared with some adhesive remover to get the old stuff off.
Popular_Culture
Thank you so much! Still waiting on the replacement cover but should be an easy replacement. I will update once it comes in
Return to “Rogue Forum”
