driftingmy240sx wrote:having been in that situation before i was able to use a large flat blade srew driver to turn it out by twisting on the ground electrode. however if the threaded sectio does not turn somewhat freely you will be in aworld of hurt as you have likely heated the aluminnum up with the excessive torque causing it to melt the threads to the steel plug. you may also want to try reverse drill bits (matco make the best set in my opinion) as when it bites it tends pull whats being drilled out with out have to really drill it out.
I agree. The flat head is a great method if you're as lucky as him. You have your work cut out for you but you should definitely try this before considering drilling/easy outing since those methods, though more effective usually will potentially intrude metal chips into your combustion chamber.
Since you no longer have the hex (bolt) part of the plug creating tension on the threads, you will not need as much torque to remove the broken stud of the plug, provided the threads are straight, clean and smooth, like driftingmy240sx mentioned. To better prepare you for this you probably should pull the valve cover and try to get as much penetrating oil inside from up top as you can, and let it soak in first. If this does not work you might want to attempt heating up the head while trying to keep the broken plug as cold as possible to expand the aluminum threads around it. If you gently use a torch, try to dry off the cams and everything under the valve cover and remove anything plastic/rubber in the way. Hopefully you wont be taking a blowtorch to your head.
Good luck.
