ianh »
https://forums.nicoclub.com/ianh-u51586.html
Tue Jan 08, 2008 6:35 pm
Standard bolts are steel, of different grades and hardness, and yes they can be drilled out.The steel extractor is hardened can not be drilled, I even tried a solid carbide metal drill,However a carbide drill may work on titanium, and i don't mean a carbide tip masonry drill, a proper metalworking carbide bit. ( assuming this is not titanium coated hardened steel)I am sorry to tell you I had to buy a new manifold !!Good Luck...
