removing broken arp stud?
bassman31386
Car: 93 KA-T and 91 stock
anybody have any clues of how to remove a snapped arp head that has about 2" or so exposed from the block? the bolt should be torqued down to + 70 ft-lb since, for some reason, the nut decided to seize on the stud without telling me. right now, i have only thought of the following solutions:
1. grind a slot in the top and use something like an impact driver/anything else that can get me some leverage (might actually work)
2. use an easy out , but i doubt it would actually grab the hardened steel that the stud is made out of, and i really don't think it would hold for the amount of torque that i need.
3. drill the bolt out, tap, helicoil, and replace with new stud
4. grind two of the sides flat so i can get a wrench on it
5. go to town on it with a set of vice grips set so tight that you have to use a second set just to close the first, and wack it with a hammer. I still don't know if the vice grips will grasp the stud since it is pretty smooth.
6. (probably the easiest) have someone weld a bolt to the stud and remove it just like any other bolt.
that's all the ideas i have. i need this stud out this weekend since it is the only thing now that is keeping my motor from running. it's things like this that really mess up a simple head gasket replacement.
Modified by bassman31386 at 2:30 AM 2/1/2006
Chezedik
Car: 1991 Nissan 240sx
I think welding a bolt is about your only hope, does ARP replace it?
TheOne
Car: 93 240sx FB
you still have some sticking out? try with the vise grips, as you don't really want heli-coils in there holding the head.
yeah thats the kind of luck that some get, a camshaft cap bolt snapped in the bolt hole, not lettin me finish doin a headgasket job in my car.(tried easyouts, that didn't work so i had to drill & use heli-coil)
Chezedik
A helicoil will be just as strong as cast iron, and stronger than aluminum. My $.02.
bassman31386
Chezedik wrote:I think welding a bolt is about your only hope, does ARP replace it?
I agree with the welding comment
i have no idea if they would replace it. i mean it torqued down fine with the first headgasket so i don't think it's really their fault. the nut is still stuck pretty tight on the broken piece of stud that i have and it won't budge. so it was either just a freak accident or some foreign object got caught up in the threads that i didn't see. either way i was able to get a single replacement stud, nut, and washer for $15.
TheOne™ wrote:you still have some sticking out? try with the vise grips, as you don't really want heli-coils in there holding the head.
yes there should be plenty sticking out considering the stud broke off right below where the washer sits for the headstud. i didn't actually bother taking the head off again since it pissed me off so bad, so i just went to do some other things i had planned for the day (removed clutch dampner box/install new slave cylinder, install exhaust, install caliper, etc). i figured that i would just worry about it this coming weekend after i had time to think the situation through.
Globalsilence
If there are threads on there double nut it, if that doesn't work, weld a nut on.
RACE 66
Car: RACEING "SPRINT 100'S" -DIRT MIDGET RACER
Take a look at this: Go to Sears, Snap-on, Mac, any well known tool vendor. They have a tool call a stud remover/installer. It works on the eccentric principle. I bought mine around 20 plus years ago and its still going strong. Mine happens to be a Craftsman and their cost is around 25.00 dollars. (Craftsmans) Go to http://www.pcmidgets.com and check out my race car, it is the # 66 midget. It is getting a 2.4 ka24e installed as we talk. Have a good one.
bassman31386
hmm. . . i didn't even know they made those. i'm definitely looking into that. thanks
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Yep, stud removal tool is how the pros do it
Its basically a one way bearing, the rollers are eccentric and some have a flat edge, works great.
This week eh Mike? Cant wait to see that beast in action
yellow_jacket
Car: 95 240sx
If you really have 2 inches sticking out, slap a pipe wrench on that sucker. If you don't have a pipe wrench, then you could buy the tools mentioned in the above posts.
RACE 66
Yep a pipe wrench would work
But a word of caution, depending what size you have ( as in length of handle) the leverage you impart upon the stud could break it off at the deck surface or below - I know been there done that many moons ago.Just don't get into a hurry on it and think it out.
