undertech »
https://forums.nicoclub.com/undertech-u65210.html
Fri Sep 04, 2009 4:18 pm
Hi guys,I'm rebuilding my 95's DE, and it's mostly together now. But I realized that I put the seal between the front cover and the block in backwards (the metal tube is going into the cover instead of the block). So now I'm faced with taking the engine apart again to put this back in properly.Can I remove the front cover without removing the head/top cover? Or will I screw up the headgasket/worse?
