removing boost solenoid
ANVIL
Car: RB25DET S13.5
so im not running my boost solenoid because I read somewhere it limits low end boost to 5psi and without it you can run 7psi. i just need to know if my vacuum lines are hooked up correctly. excuse the drawing but you should get the point.
that look about right or do I have something wrong?
the bov is on the intake side of the ic piping and the T goes to the exhaust side
Shocker
Car: 89 240sxHB rb26/30
yup you got it.
240sxr33
Car: Cars (imports)
It is other way around.With boost solenoid you can run 7 psi,without it 5.
Shocker
240sxr33 wrote:It is other way around.With boost solenoid you can run 7 psi,without it 5.
You can just install a MBC where between the T and the wastegate, make sure you have a boost gauge crank it up to 9-10 and just leave it.
RB_Dreamin
Shocker wrote:yup you got it.
please explain the purpose of the T?
Shocker
RB_Dreamin wrote:please explain the purpose of the T?
none really, just keeps him from having to get a longer vac line to the plenum or having to get a new connector. Doesnt hurt a thing. But if he wanted to clean it up sure he could remove it.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Quick question??Why is the IC piping hooked into the vacuum lines??
RB_Dreamin
doing it the way pictured is redundant.
either connect the wastegate to the IM and cap the piping or cap the IM and connect the wastegate to the piping. if i were you i'd feed the wastegate from the piping and use the IM port for a boost gauge to read psi at your manifold.
Joe
RB_Dreamin wrote:doing it the way pictured is redundant.
yup there is no reason to have the manifold and IC piping connected to the wastegate
but just cap the manifold, there is already a nipple on the back of the intake manifold for the factory RB25 boost sensor for the cluster.
and also correct with whoever said withOUT the solenoid you only run 5psi, then with it you run 7. you will need to get a MBC or EBC to run more than 5.5psi (wastegate spring pressure)
