Hullo brake experts.
I am wondering if it is possible to remove the rear bias valves from a 300ZX or 240SX master cylinder to leave it at a 50/50 pressure split. Then I can use a proportioning valve on the rear if the rear has too much force.
I have 26mm Z32 brakes up front and the stock MC and there is just too damn much bias up there for my tastes. I am going to upgrade to a Z32 MC but I haven't decided 1" or 1 1/16". I don't have ABS.
I know the miata guys have it easy, their stock proportioning valve is external to the MC, but we don't have that tuning luxury.
Looking for feedback on the MC sizing issue. I have a manual 240, and don't want to swap brake boosters. I would like to improve brake modulation so I don't want it too stiff, but I don't want it mush like it is currently. Any opinions on MC size?
In the event that removing the stock proportioning system is not possible, is it reasonable to put a proportioning valve on the front brakes? Do they make proportioning valves with 2 inputs and 1 output? Is it reasonable to reduce front braking force in general? How does that effect tuning the pedal feel?
I have searched and found some vague answers to some of the questions, nothing for the rest, so hopefully I can get some insight as to my upgrade path.
Thanks
