oobabydoll »
https://forums.nicoclub.com/oobabydoll-u29502.html
Tue Jun 07, 2005 9:17 pm
I did replaced my own ball joint and tie rod ends. I followed some dummys advice and spent $100 on a balljoint removal tool and it just busted on me. I got some great advice kocked the **** out of it with a big hammer and pow! Bam! it came out in a second. These are the instructions i followed
UPPER
1. Raise and support front of vehicle and remove wheel. Do not raise on lower link assembly. 2. Remove shock absorber upper attaching bolt, if necessary. 3. Using suitable jack, raise lower link and remove upper ball joint tightening nut, then press ball joint out of knuckle. 4. Remove the upper link spindle attaching bolts and upper link. Adjusting shims are behind spindle. 5. Remove ball joint attaching nuts, then the ball joint, Figs. 1 and 2. 6. Remove nuts and washers from both ends of upper link spindle, then press spindle and bushings out of link. 7. Reverse procedure to install.
LOWER
1. Raise and support front of vehicle and remove wheel. 2. Remove torsion bar, refer to TORSION BAR . 3. Remove lower shock absorber attaching bolt. 4. Disconnect stabilizer connecting rod and tension or compression rod from lower link. 5. Remove ball joint tightening nut, then press ball joint from knuckle spindle. 6. Remove the lower link spindle and lower link assembly. 7. Remove ball joint attaching nuts, then the ball joint, Figs. 1 and 2. 8. Remove nuts and washers from both ends of lower link spindle, then press spindle and bushings out of link. 9. Reverse procedure to install.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
