Removing an installing injectors and brake master cylinder?
240SX_89
Car: 1989 Nissan 240SX Fastback
Well i found a 89 for sale all it needs is two injectors and to replace the BMC. I got a 89 240 that i could take the parts from. My question is how do i remove both the injectors and BMC and reinstall in the other 240. I tried SEARCH and articles but nothing came up so if i could get some help that would be great.Thanks
ricebike
2002 Quest
2005 Altima
autozone has a chilton's based manual that you can look it up for free...
or d/l the FSM & unzip/read to your heart's content!
ricebike
2002 Quest
2005 Altima
search button had lotsa hits on this one!
zerothread?id=131576
zerothread?id=85319
zerothread?id=77256
zerothread?id=54456
& then if you search "fuel injectors" w/ "Archived content" highlighted, you'll get more results
240SX_89
Thanks for the help i downloaded the FSM.
I see that you are looking for a few parts for your car. I got a 89 240 sitting in my driveway. I may have a few of the parts that you are looking for, email me at [email protected] if interested.
ricebike
2002 Quest
2005 Altima
did u email me @ my yahoo acct earlier?
240SX_89
Yeah
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Here's a procedure that was originally posted by navysnail:
1: remove gas cap2: remove fuel pump fuse3: crank engine untill it dies4: remove fuel hoses going to fuel rail, label them so they dont get mixed up5: label the injector wires (1-4)remove the wires (you have to pull out a little metal clip) and the fuel lines6: remove the 2 bolts on the fuel rail7: remove injectors8: put new seals on all the new injectors and all injectors that were removed9: put some oil on the seals, then push them straight into the rail, not at an angle, and dont twist10: assemble everything back together, and turn the key to on a few times, make sure the fuel isnt leaking, then go ahead and start her up
