Removing Altima Coupe Door Panels
Troubleshooting, DIY's, How-To's and articles about all Nissan vehicles. Non-vehicle specific "General" How-To and tech information is also here.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Ok, how to removed door panels. Here we go:
First, pry off the cover inside the door handle. Then unscrew the screw inside.
Now, pry up the cover starting from the bottom.
Once unclipped, undo the wire connection. Then place the assembly aside.
Now pry off the trim peace, starting from the rear, and moving foward.
Then pull it away...
Now, pry out the door light and unclip it
Remove the screw under where the trim piece was
and the one where the window switch was
Now begin prying off the actual door panel. There were a total of 3 screws removed.
A shot of panel off. Thats hushmat on there. I tried it out for my local shop. Works as well as dynamat, but costs the same too. And not as available. B-quiet so far is the best for cost and effectiveness. Good luck!
Article by : vballer22
Return to “Nissan Articles”
