that will work or to make it easier on you. just use the line to grab a corner of the letter and pull straight back on it. it should pull the tape off with it. cause depending on what color your car is... if you rub too much you can put swirl marks in the paint if you arent carefulpackerjd04 wrote:Yep just use a hairdryer to heat it up and some fishing line to take them off like smithers said. Make sure you go in between the lettering and the glue and not the glue and the paint! Clean it off with some goo gone or whatever, wash it up and maybe wax it or whatever and your good to go!
You can also use dental floss (if you don't have any fishing line lying around like me).ThatGuyRoger wrote:it was really easy, i used fishing line, and didnt have to heat the letters up. although it was blazing hot that day. but it took a little over 5 minutes taking the letters and glue off.
