Removing alternator (1990 S13)
NYIntensity
Car: 1990 240SX Hatchback
Yes, I searched, but I really can't find anything specific to my problem. Before I go crowbar/hammer, here goes: Okay, got the wire harness, ground, and whatever the 3rd little wire is off the back of the alt; tensioner loosened and the 12mm bolt removed, and the 14mm bolt off the bottom removed, but still, no "removey". It will wiggle back and forth (same angle as it would if you were adjusting the tensioner, but I can't pull it out...what am I missing?
TestBedWilly
Car: 240 SX
I think they are just stubborn. Got mine out a week ago after finding the same thing you feel. I think it's just really pinched by the lower attachment, so if you wiggle and apply a little leverage at the bottom, it should come out.
