gniknave »
https://forums.nicoclub.com/gniknave-u19269.html
Sun Apr 17, 2005 12:31 pm
I've bled my 240's cooling system a few times in the past day for various reasons. NISTECH told me a nice procedure to do it. I'm sure the procedure is similar, but here's what he said.
Drain the radiator with the cap removed.
Replace the drain plug & fill the radiator.
Once the radiator is full, fill the reserve to "Max"
Put a bleeder funnel in the radiator filler neck and fill it half way (level shouldn't go down)
Start the car and turn on the heater full blast
Let the car warm to normal operating temperature
Once it is in that area goose the throttle, let it come back and stabilize at idle, then goose it again, and let it idle for a couple minutes. Do this for about 10 - 15 minutes after it reaches operating temperature. (may be shorter time on the Q)
The key is to let it settle at idle between each goose. Without the radiator cap on the system can't really build up pressure, so the goosing of the throttle from idle gives it a bit of pressure by speeding upthe pump sharply. When goosing the throttle, you are snapping it to around 4 - 5k rpm and letting go. Don't hold it there.
When I did this I noticed that after 5 minutes I saw large air bubbles come from the funnel and then it tapered down. Eventually I saw no bubbles at all.
When all the air seems to be out then shut off the car, replace the radiator cap, and top the reserve to max again if it is low.
He also recommended it being on a slight incline (I had it on ramps) when doing this procedure.
