Leo2005 wrote:That's what you do...pry plastic clips with screwdriver.
Almost Leo...
If you try to pry the whole clip, you'll break it.
The clip is in 2 pieces. You have to pull up the center portion or 'pin' using a wide flat screwdriver. You may need to work around the pin in several locations gently prying until it comes loose. When you get the pin about 1/4" out, the main part of the clip should be loose and can be removed by hand.
Installation is the reverse... insert the clip, then push the pin to lock it in place.
