Nope, according to the service manual, you have to remove the instrument panels (instrument panel finisher B and C) on either side first, which should pop out.Ilya wrote:I believe it just pops out with some light prying...but someone else can probably chime in and confirm that.
Good work sir. Didn't have access to the FSM handy, way to come through. OP, download the FSM from the FAQ thread.pedsemdoc wrote:Nope, according to the service manual, you have to remove the instrument panels (instrument panel finisher B and C) on either side first, which should pop out.Ilya wrote:I believe it just pops out with some light prying...but someone else can probably chime in and confirm that.
The multi-function panel has one screw on the driver side and a connector in the back with clips along the front.
Check out the service manual:
AV-292 and IP-10
Nah, it's a breeze. For someone who's never done it, shouldn't take you more than 45min or so, and that's with a few "WTF" moments.airmanhoward wrote:Thank you pedsemdoc. Looks like a couple hour job just to change out the panel.
