Removing ABS
Kamahl
Car: 1995 Nissan 240SX
I want to remove my ABS system from my 95 240sx base model. I know that the unit in the engine bay is for abs, but if i simply remove that, what will I have to do with the lines? And what do I have to do in regards to wiring or sensors? Is it OK to keep my stock brakes or will they mess up?
Thanks for any input - and sorry if this was covered before, I searched but didn't find anything about removing abs.Thanks!
180fan
Car: 89 fastback
you'll pull the sensors at the wheels and diff and get the non-abs hardlines
working4aS13
Car: Base 95 240SX
Kamahl wrote:I want to remove my ABS system from my 95 240sx base model. I know that the unit in the engine bay is for abs, but if i simply remove that, what will I have to do with the lines? And what do I have to do in regards to wiring or sensors? Is it OK to keep my stock brakes or will they mess up?
I did a search but it didn't yield anything either. Which is strange because I posted on the subject no to long ago:
zerothread?&id=223530
Kamahl
yesss thank you very much guys!
