Do you have any pictures of this part installed?working4aS13 wrote:I've recently removed the ABS actuator from my 240. There is a Nissan part that I order that simplified the job. 02463-13100, I bought this part at Courtesy Nissan for $8.05 but it is a speciality part so you'll probably end up waiting a week for it. You don't need a new master cylinder. This part connects the front lines to the brake master cylinder with the existing lines that go to the ABS actuator. As for the rear line, there is a short line that goes from the ABS actuator to a female female union attached to the frame. You will need to remove that line (its about 6 inches long) and connect the rear line coming from the brake master cylinder to that female union.
im pretty sure they fit stock se wheels also...they are just a tad bit bigger as far as i knowSyndromeVII wrote:I think j30's will fit stock rims, i will check tomorrow if they do, if it doesn't snow.
That is why the first photo is blurry, I had to stand outside (while in shorts) to take the photograph.bone_stock_240 wrote:It is negative stupid degrees outside.
I think I have a vague idea, I used to live in Germany.bone_stock_240 wrote:No offense, but I don't think you know what cold is until you experience a Canadian winter.
As for my ABS actuator didn't consider selling it but I suppose I could because I'm doing the full Z32 brake upgrade and the rear won't have the ABS sensors. The fronts probably won't either as I purchased S14 base uprights.bone_stock_240 wrote:What are you going to do with your abs unit? Is it worth me trying to get mine working again? Pretty expensive part, should be able to get a decent amount for it, that is if someone actually wants to buy it.
Awesome!! Did you ever get that part in?bone_stock_240 wrote:I ordered mine from Pinnacle nissan. Cost 8 something + shipping
http://www.nissanparts.org/
There are 2 different part numbers for it, so you could also try this 46364-50F00. This site had pictures and instructions but the pictures do not work anymore.
http://www.npclub.com/bb/print...28501
Yes it is the same part.MTX450 wrote:I'm not completely sure, but maybe someone can clarify...is this connector the same connector that splits the brake lines in the rear?
