Well, there is rain, but I agree. If I had a G50 with TCS, I would rip it out and keep the four channel ABS.Q45tech wrote:In my opinion the TCS should be permanently disabled whenever the temperature is above 45F.............assuming the VLSD is functiong as new.
Rear brake pads will last longer, tires may not. But you probably won't get rear ended by a SEMI.
