removed: secondary intake butterflys? Bad Idea?
uncle_louie83
Car: 1993 Nissan 240sx Coupe
Well...when i rebuilt the motor...i removed the butterflys inside the upper intake manifold....ive done this on all my honda motors so i figured why not with the nissan. Well i GUESS it was a mistake...car idles low (650 to 750 rpms)...and when drive the car, if i get the motor in upper RPMS...and i put the car in neutral and let the rpms just fall down, the motor will die...i start the motor...and it idles steady at 650 to 750 again and then i just keep driving...i believe this is because i removed the secondary butterflys (SCV). But im not sure though....please give me some insight to this...cause im gonna end up putting it back on if this is my problem...
lewis
uncle_louie83
i guess no one knows anything....im gonna post this on freshalloy
madbouncy
Car: 93 Mazda RX7 R1
650-750 isn't a low idle. The manual says the idle should be 700 + or - 50. So you're fine there. Haven't removed mine but I'd say to make sure you don't have any leaks anywhere. Never read about anybody having a problem like that when removing it.
SMoKeM240
Car: 89 240sx NA/KA
i removed mine, and all emisions crap and i have no problems
NismoGreg
Car: '93 s13 fastback se, '87 200sx se v6,'91 integra ls
When I blew up my stock ka in my '93, I purchased a de from a junkyard that came from an automatic 240. The automatic ka does not have secondary intake butterflys in the manifold. My motor runs strong and has more power than my other de did.
uncle_louie83
mmm...must be the timing then...thanks for your time.
lewis
s13sr20chris
did you also remove the rod they move on? if so that could be a vac leak right there.
Dattebayo
The secondary intake butterflies are called the SCV.
(swirl control valve)
They control your low end power and can make the top end a little unstable in a stock KA if removed, but that is up for disscussion as I have never done it and lots of people say different things about it.
The CA18DET guys have a similar setup in their motors and they usually just remove those butterflies so they have access to more top-end power (I guess since their displacement is not as large). They are definatly a barrier to a high-power motor.
The S14 motor does not have them so maybe you would want to switch to a S14 manifold if you are considering building a monster engine.
uncle_louie83
knaw i left the rod on there...i just turned the idle screw til i reached 900rpms at idle...i like it better at 900.....makes me feel better...the idle screw is almost all the way out now....mmm...oh well....im taking the car home tonight and then ill investigate more into my problem.
lewis
Dattebayo
The engine should not be kept at idle that high.
Please lower it, your feeling is not worth screwing up your engine.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
uncle_louie83 wrote:knaw i left the rod on there...i just turned the idle screw til i reached 900rpms at idle...i like it better at 900.....makes me feel better...the idle screw is almost all the way out now....mmm...oh well....im taking the car home tonight and then ill investigate more into my problem.
lewis
For the love of god lower your RPM back down to 700 this is not a RICE Honda it was designed for that idle you will screw up your motor and have to buy another one
NateDogg
Please enlighten everyone how having a 900rpm idle will "screw up your motor"?
SMoKeM240
Car: 89 240sx NA/KA
mine idles around 1000 and its fine... and how does it ruin it? thats the dumbest thing i heard
All_Motor_KA
Car: 1989 240sx SE
Some people like haveing there engines more then 2 years...
uncle_louie83
how in the hell would a 900rpm idle **** up a motor? only thing its gonna do is just burn more fuel.....when i left the idle at 700rpms and drove the car around....and immediatly let off the gas....the motor would die...and then i would have to restart it or put the car back in gear while i was rolling.....i think something is still wrong with my timing...oh well.....i gotta stop lending out tools....my torque wrench is 35 miles away and it pisses me off when they wont return them in a timely manner so i can work on my own car.
lewis
p.s. none of my motors have ever lasted 2 years....i blew them all up with too much boost...i know this motor wont be in the car for more than a year because ill end up boosting it way too much.
