Removed A/C need new tune?
SRrunner
Car: SR20det s13 Fastback
Hey i just removed ALL of my A/C last night including the pulleys now when i started it this morning it idles at 1800 the when i rev it abit i goes down to 1300 but used to be at about 900 so i was wondering if anyone knows if i need a retune
Thanks
Cone Junky
Car: S13 fastback
BMW e46 328i
It should not effect the idle that much. The decrease in load and drag might change the idle speed a little, but 400-900 rpms seems extreme.
Is this with the A/C button activated? I also removed my A/C and will purposely activate the system to raise idle and turn on the auxillary fan occasionally. That is the only time I noticed an idle change. But then again, the A/C was removed when I completely rebuilt and modified my motor, so I guess I can't really say what the difference should be with only removing the A/C. Either way, it shouldn't be anything a turn of the idle screw can't fix.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Let it warm up and follow the process in the FSM to reset the idle speed.
SRrunner
Well i didnt know if i left it active but why would it matter if i removed everything
SRrunner
Yea im gonna do that when im done wiring my alarm/sound system so ill let you know tonight how its workin
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
if the electrical is still functional, when you press the button it activates the FICV(fast idle control valve) witch raises your idle. removing ac shouldnt affect your idle like that
SRrunner
idk if this would make any difference but i just installed the Nissan Quest alternator so i would have more amps
SRrunner
Its working great now i tightened up the belts a bit more and let it run for about 15 mins then drove it so it seems to be all fixed love the new alternator aswell
