remove windshield wiper reservoir
LiU
Car: Cars
has any1 removed this for weight reduction? I heard it's a good 20 lbs.
daniel240
Car: cars/motocross
LiU wrote:has any1 removed this for weight reduction? I heard it's a good 20 lbs.
20lbs? maybe when it is filled up. when it is empty it probably weighs 1lb. just keep it empty if your worried about that little extra weight.
midwestdrifter
i took mine out because i hate it. hoses mounting bracket and all maybe 5 lbs. again its just personal, i just dont like the sprayer.
there was an article about making it into a intercooler/radiator sprayer. so you might want to keep it.
daniel240
Car: cars/motocross
midwestdrifter wrote:i took mine out because i hate it. hoses mounting bracket and all maybe 5 lbs. again its just personal, i just dont like the sprayer.
yea but your still left with the squirters sticking out of the hood.and yes i saw that in the scc mag. i may have to try that. i never use mine anyways, if you use rain-x you never need the windshield sprayers.
LiU
Car: Cars
ahh yes I looked at the thread again and it said full w/ water. Looks like I'm keeping it - so far I've removed spare, jack/tools, stripped trunk, contemplating whether it's worth it remove rear seat (upper and lower), should be good for about 15 lbs
black180sx
i took mine out to make a custom shortened cold air intake.
BuudWeizErr
I took mine out when I installed my front mount and never put it back. And I don't have any plans to put it back either.
Structure240sx
mine had a leak in it. i took it out when i got my kit put on since it was easy to see and i never needed it anyway.
240marcuSX
Car: E34 525i
E46 M3
ive often wanted to take that out when working on other things under the hood, but just never did, perhaps i will when i move the battery and get an elec. fan.
Cyberkreig
Car: 1993 Nissan 240SX SR
Mine is out & laying in the garage. But i think they check for working sprayers as part of the PA inspection..
Hijacker
Car: '92 240sx Convertible
'94 F-150
my car didn't have one when i got it. problem solved :D
it still seems kind of silly to think that the removal of the resevoir is equal to a major weight reduction.
midwestdrifter
i think of it more as a visual improvement. it cleans up the engine bay. i was thinking about taking out the nozzles on the hood to smooth it out.
one should be careful with that rain-x. it eats away at the glue used to hold the glass in place. after a while the glue leaks down the paint and discolors the paint.
book-ends
Car: ???? Nissan 240SX coupe S13
What do you guys do in the snow? Obviously not everyone lives in a snowy winter climate but damn! I've refilled my reservoir twice in the last two weeks already because the s*** they spray on the roads makes my windshield all "sticky" and cloudy.
BuudWeizErr
What exactly is this "snow" you speak of?
cheez80
Car: percussion =D
i don't have mine installed
took it out to install my oil cooler :)
daniel240
Car: cars/motocross
or you could turn it into an intercooler sprayer.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
mine sprays like above my windshield, sometimes it gets on my sunroof
