DrifterProdigy85 wrote:is there a way to remove valve springs without taking the head off? sorry if im jacking the thread some but it seems to follow the topic. i want to upgrade my cams to HKS 264 + 272 Step 2 but i dont feel the need to remove the head.
yes there is. There is a tool that allows you to compress the valve springs w/o taking the head off. Many varieties exists. The ones you twist or ones that hook on to the cam on the opposite side and compress valve springs.
You do need an air compressor because you have to put combustion chambers under pressure so that your valves dont drop when you take the retainer and collars off. The valve seals do hold on to them a little bit but Id rather not take the chance.
