Remove trailer hitch
naladude911
Car: 2001 Infiniti QX4
My friend with an R50 wants me to help him remove the rusted out trailerhitch. Its just the 4 bolts that connect it to the chassis right?
Pwnin O'Brien
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
Should just be the bolts on either side of the hitch. I think mine has four on each side, though your install could be different.
Make sure you have an impact wrench or a long breaker or cheater bar. If properly installed those bolts should be pretty tight, and the rust won't help things. A torch could also help things, just keep it away from any fuel lines back there. :P
naladude911
Yea, I meant 8 bolts. So a plain old socket wrench won't work?
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
it will with some elbo grease, i soaked the bolts in wd-40 even though they werent rusted like 30 mins before, then i used a rachet and got them off, but its a little pain in the a**, but it came off.
