Post by davidarmy » https://forums.nicoclub.com/davidarmy-u52392.html Wed Mar 19, 2008 10:16 am
Post by BoBa524 » https://forums.nicoclub.com/boba524-u20027.html Wed Mar 19, 2008 10:43 am
Disconnect your battery 15 mins prior to, pop off covers on both sides of the steering wheel and whip out your temper-proof torx(dunno what size) and unscrew the two bolts. the airbag then comes out.davidarmy wrote:What is the proper way to remove the steering wheel. I also have a WB hub with SRS delete and would like more info about the wiring both horn and resistor placement
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
