Remove power outlet from center console Nissan Rogue 2017
mm49061
Car: 2014 Nissan Rogue
I am trying to remove the power outlet from the center console of my 2017 Nissan Rogue to replace it with a dual port USB. I have pulled the cup holders up so I have access to the inside but I cannot see how it comes out. MY wife's Subaru had two clips you pinched and then it slide out and my Tundra just had a key way to line up and slide out. I've looked with a mirror and searched online and cannot figure this out. Any help would be appreciated. Thanks.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
second gen nissan rogue center console removal
About 990,000 results (0.70 seconds)
Nissan Rogue Service Manual: Center console assembly
mm49061
Thank you. I have that diagram but it doesn't really explain how to remove the power outlrt. I do not want to remove the whole console.
zukabaker
Car: 2019 Rogue SV AWD
POWER SOCKET
Removal and Installation
FRONT POWER SOCKET
Removal
Remove cluster lid C. Refer to IP-21, "Removal and Installation".
Release the pawls on the power socket and remove from the cluster lid C.
Installation
Installation is in the reverse order of removal.
CONSOLE POWER SOCKET
Removal
Remove center console assembly. Refer to IP-18, "Removal and Installation".
Release the pawls on the console power socket and remove from the center console.
Installation
Rogue One
2022 Honda Pilot SE
mm49061 wrote:
Sun Apr 26, 2020 4:14 am
Are you familiar with the saying that you have to break some eggs if you want to make an omelette? Design engineers don't keep shade tree mechanics in mind when drawing up plans. Basically that means that you may well need to remove more than you'd like to, because that's how the car was put together. I know it sucks, but sometimes it seems like the folks at Nissan go out of their way to make simple things harder than they should be (the Rogue cabin filter is a prime example of this).
mm49061
So I figured it out. I used my Depstech endoscope camera ( https://www.amazon.com/gp/product/B01MY ... UTF8&psc=1 ) to get a closer look and there is a tab on each side that holds the power outlet in. I tried using screwdrivers and plastic pry tools but could not get it out. I ended up taking a zip tie, wrapped it around the outlet at the top and pulled it tight. I pushed from the bottom and it popped out. So now I'll order the dual USB outlet.
Return to “Rogue Forum”
