Can anyone help this guy out?l0nestar wrote:Alright everyone, quick, basic, to the point.
How do I remove the oil pump?
I used pages EN-120 and EN-131, but they did not provide much information other than EN-120 stating about a 'seal cutter', but I do not want to remove the entire oil pan if I do not have to. I did notice that all of the bolts that I removed had the factory gray 'loctite' on them, so that was nice. I could not find a place to break the seal to pry the pump off. (I do realize that when I go to remove the pump it must be pulled straight off (evenly) and not 'c***-eyed'.
Background:I have been dis-assembling the RB25 and got to a stopping point. I cannot remove the Oil Pump. I have removed the upper timing cover, main pulley, timing pulley, timing belt, and tensioner (or idler, cant remember which is which.) I removed all of the bolts from the pump and labeled and bagged them along with the bolts from the oil pan under the pump. I also removed the first two additional oil-pan bolts and loosened the next two as well. Do I need to remove the oil-pan completely first??
Sorry if everyone gets tired of me asking what may appear to be elementary questions. I look at a problem, attempt to solve it, research FSM, then search, THEN ASK! I don't know everything, but I am always ready to learn something! Plus I don't want to d!ck up anything on my RB. It is always better to learn from other peoples mistakes And I think that is also an important aspect of this forum that may be over looked some times.
Thanks!l0nestar.
Carl,What type of lube is it? If I go to an AutoZone and ask for 'Assembly Lube' _should_ the attendant have a clue? Is it similar to cam lube?.. Just went to SumittRacing, is this what you are talking about? (below) Do you suggest literally filling the pump with the fluid or just making sure it is well lubricated and filling with some engine oil before I attempt to start it? (I know about priming before you start, but thanks for the remind! ) Also, on another thread you said something about dis-assembling the pump and red loc-titing the screws. Is this a normal thing, or more of a race thing? Just wondering. Thanks!Carl H wrote:i highly sudgest filling your new n1 pump with assembly lube as it will help it prime and get oil flowing faster on startup...course you should always prime the motor before first restart anyways.
You may be able to get the pump out without lowering the pan. But getting it back in is a different story. This was one persons idea of how to get the pump installed without lowering the pan...gawdzilla wrote:i think its possible to remove the oil pump without removing the pan. you'll just find it is a lot easier if you break the seal between the pump and the pan by removing the pan first.
also, if you remove the pan, its easy to pry at the pump from the back if its stuck on there. there are 2 dowels that help line the pump up to the block.
another thing to note is if you do not drop the pan just a little bit that regulator bolt on the bottom might interfere with the pan.
i would drop the pan, its not a big deal. liquid gasket that you can just clean off and redo. just try not to get crap into the pan while you're doing it. plus it gives you a chance to glance at your bottom end
A few years ago I purchased what was supposed to be a disassembled complete RB26 less the block. Thought it would work out great for the RB30 block. Well, the oil pump was just one of the suprises. Much of the parts and bolts were expensive paperweights.Before I sold some of the parts from it I had them checked out at the machine shop first. I just cannot sleep at night knowing I deliberetly sold crap to someone!l0nestar wrote:My Gosh Stealth-Z, I want to know who to _NOT_ take work to after seeing _that_. Scares me! Now that is the reason I do all of my own work...
Stealth-Z, My Gosh... an RB30DETT into an old Fairlady. Nice! I bet that thing will move and surprise a _lot_ of people!Stealth-Z wrote: Don't feel to bad about the crank collar. I had it installed on my RB30 crank.
